[FAQ] READ FIRST! Frequent Questions for Desktop Computers
Gbilato
Moderator
Donator
Hewlett-Packard
i7-5500u
Intel HD Graphics 5500 + nVidia GTX950m
10.14.x
Clover (UEFI)
iMac, iMac Pro, Mac Pro, MacBook, MacBook Pro
Android, iOS, Other
Before creating a post where you ask something, read this post and try to use the search function, because someone else could have already written a post for your hardware and the related questions.
As this is a specific FAQ thread, so please do not ask questions regarding the issues you're having. If you have any topic to discuss with or have any question to ask, please use the appropriate forum and open a separate thread instead. If you have something you'd like to add to this thread, feel free to reply here.
If you can't find the answer after you've read this thread, and searched into the forum with the search results, then you can create a post with your particular question.
But now, let's start!
Q: First, is my Desktop PC compatible?
A:
Read the compatibility thread here: https://www.elitemacx86.com/threads/read-first-desktop-compatibility.141/
Q: From where I need to start
A:
Checking if your hardware is compatible, and you can follow our thread here: https://www.elitemacx86.com/threads/read-first-desktop-compatibility.141/
If you are using any other bootloader, it's good to switch to Clover as it as several advantages. You can use Clover for Legacy and UEFI.
Before you start with all these stuffs, find your hardware details.
The details you need
  1. Motherboard model
  2. CPU model
  3. Graphics
  4. RAM
  5. Audio Codec
  6. SATA Information
  7. USB Information
  8. Ethernet/LAN
  9. WiFi, if available
  10. Bluetooth, if available
To find out the details, a guide has been already written. For more information read here: https://www.elitemacx86.com/threads/guide-how-to-find-complete-system-information.300/
Your profile should reflect the hardware information. Do not use Signature to provide your system details. You can use signature for the other systems you might have.
To edit your profile, you can find the User Menu at the bottom. Just click on Account Details and you can enter/update the details over there. You can also edit your profile by using this link: https://www.elitemacx86.com/account/account-details
The four fields must be filled out as follows:
  • Motherboard: Manufacturer name and model
  • CPU: CPU model
  • Graphics: Available graphics device
  • Bootloader: Clover(UEFI/Legacy)
Motherboard - This include your motherboard model no. along with the manufacturer name.
CPU - This include your CPU model no. along with the manufacturer name.
Graphics - The Graphics device model your system uses. Either NVIDIA, AMD, or Intel HD Graphics.
OS X/macOS - The OS X or macOS version you're trying to install or has been installed.
Bootloader - Select the Bootloader according to your System. Either Legacy or UEFI.
For example, typical hardware information for a desktop:
Motherboard: GIGABYTE Z370 AROUS GAMING 7
CPU: Intel Core i7-8700K
Graphics: nVidia GTX 1080Ti
Bootloader: Clover(UEFI)
The profile is for the current hardware, you're seeking for support. Once you complete the hardware, you can use it under your signature. Use Signature for your rest hardware.
To edit your signature: https://www.elitemacx86.com/account/signature
Please provide your signature details for each specific system in a single line.
Q: Can I download Sierra?
A:
Yes, you can. Following this link will guide you through all the steps.
Q: Can I download High Sierra?
A:
Yes, you can. Follow the link here: https://support.apple.com/macos/high-sierra
Q: What if I haven't access to a real Mac?
A:
Ask to a friend or colleague who has a real Mac or buy a Mountain Lion DVD, install it, make the Ethernet working and then download macOS.
Installing OS X on a new and modern hardware can be difficult and there can be other issues.
Probably asking a friend to use their Mac is a better idea.
Q: Is there any guide for installation?
A:
Yes, the guides are available.
For 10.14.x: https://www.elitemacx86.com/forums/mojave-desktop-guide.46/
For 10.13.x: https://www.elitemacx86.com/forums/high-sierra-laptop-guides.43/
For 10.12.x: https://www.elitemacx86.com/forums/sierra-laptop-guides.44/
Q: How do I install Kext?
A:
Installing a kext is very easy. There are various method to install kext. For more information, read here: https://www.elitemacx86.com/threads/guide-installing-kexts.259/
Q: If I have an existing installation of Windows and don't want to remove it?
A:
You can configure it as Dual Boot. Better if you install from scratch. Installing with pre-installed Windows can be possible but it can create several issues, so it's your the decision to install it with or without Windows already installed. Read here : https://www.elitemacx86.com/forums/multi-boot.54/
Q: Do I need to set DVMT-prealloc to 64MB?
A:
DVMT-prealloc is only required when you are using IGPU (Intel HD Graphics). For a external graphics, such as nVIDIA or AMD, it's not required.
Q: Is Coffee Lake supported?
A:
Yes, coffee lake is supported.
The coffee lake CPUs are natively being recognized on macOS High Sierra. However there are graphics notes. See below
Q: Is Coffee Lake and Kaby Lake-R Graphics supported?
A:
Yes, the above graphics are supported. Not natively but spoofed. You can use the KBL graphics drivers by using FakeID/IntelGFX and FakePCIID.kext + FakePCIID_Intel_HD_Graphics.kext.
More has been covered here: https://www.elitemacx86.com/threads/fix-intel-uhd-graphics-630-on-10-12-6.217/
Q: I've got a NVMe drive. Is it compatible?
A:
Yes, it is and you can use it as boot drive. Our suggestion is to use Solid State Drive or NVMe Drives to have a faster system. And obviously, to use Samsung ones. With High Sierra and later, the NVMe drivers are supported out of the box. But if you're planning to use Sierra, you'll need to add some patches. For more information, read here: https://www.elitemacx86.com/threads/guide-how-to-use-nvme-and-m-2-drives.290/
Q: If I've got a 4k monitor can i use that?
A:
Yes, you can. If you're using IGPU (Intel HD Graphics), then you need the following:
  1. Need to patch the IOKit framework
  2. Need to set the DVMT to 96 or 128MB in BIOS
If you are using a external graphics such as nVIDIA or AMD, there's no such requirements.
Q. My Keyboard/Mouse doesn't works. How do i fix it?
A.
The non-functioning of Keyboard/Mouse is likely due to non-working USB ports or missing kexts. Read here: https://www.elitemacx86.com/threads/fix-keyboard-and-mouse-when-installing-os-x-or-macos.292/
Q: I've got a problem. My USB isn't working. What can I do?
A:
On some systems, the USB ports can work. It depends on the chipset used by the motherboard. For a working USB ports, you need to follow some additional steps. Follow the guide here: https://www.elitemacx86.com/threads/how-to-create-custom-ssdt-uiac.219/
Q: My Ethernet is not working. What should I do?
A:
Every Ethernet has a different chipset, to enable the ethernet, you need to install driver for your ethernet chipset. For more information, read here: https://www.elitemacx86.com/threads/guide-how-to-enable-network-adapters-on-any-given-desktop-pc.254/
Q: My WiFi isn't working. What can i do?
A: For a working WiFi, the hardware must be compatible. See the compatibility guide.
Q: My Bluetooth isn't working. What can i do?
A: The non functioning of bluetooth is likely due to non-working USB ports. Read here: https://www.elitemacx86.com/threads/how-to-create-custom-ssdt-uiac.219/
Q: I'm unable to turn off the Bluetooth
A:
This is when using a unsupported hardware. The WiFi and Bluetooth might work but you won't be able to get all the functions as it's not fully supported. Better to replace with a compatible WiFi hardware.
Q: Can i use a USB WiFi Adapter?
A: Yes, you can use it but it can cause problems like improper sleep. Can be unstable and hard to find device driver for some manufacturer/models. Even if you tend to use, just install the driver from the manufacturer website.
Q: The Audio isn't working.
A:
There are various methods to make the audio working. The preferred method has been covered in the desktop forum. Read here: https://www.elitemacx86.com/threads/guide-how-to-enable-audio-on-your-hardware.99/
Q. HDMI Audio is not working. What can i do?
A.
HDMI audio doesn't works by default. HDMI has several requirements.
For IGPU (Integrated Graphics)
  • Inject "hda-gfx"="onboard-1" for HDMI Audio
  • Layout id injection
  • A patched framebuffer
  • A working Audio with a valid method. VoodooHDA is not a valid and recommended method to use.
The guide for IGPU HDMI/DP Audio has been covered here: https://www.elitemacx86.com/threads/guide-enable-intel-igpu-hdmi-dp-audio-sandy-ivy-haswell-broadwell-skylake-kaby-lake.100/
For external graphics, see here: https://www.elitemacx86.com/threads/guide-how-to-enable-nvidia-hdmi-dp-audio.101/
https://www.elitemacx86.com/threads/giude-how-to-enable-hdmi-audio-on-amd-gpus.258/
Q: The Audio is not working after Sleep/Wake Function. What can i do?
A:
For some audio codecs, it's possible that the audio will not work after sleep/wake function. For more information, read here: https://www.elitemacx86.com/threads/fix-no-audio-after-sleep-wake-function.102/
Q: My nVIDIA GPU is not working. What can i do?
A:
There can be various reasons. There is a guide to enable nVIDIA graphics. Read here: https://www.elitemacx86.com/threads/guide-how-to-enable-nvidia-graphics-in-macos.104/
Q: I've a AMD GPU, it doesn't works. What can i do?
A:
Not all AMD GPUs are supported. There's already a guide for enabling AMD graphics. Read here: https://www.elitemacx86.com/threads/guide-how-to-enable-amd-graphics-in-macos.214/
Q. Brightness does not works. How do i fix it?
A.
Brightness doesn't works on Desktops.
Q. My Mac App Store doesn't works. What can i do?
A.
For a working App Store, the Ethernet bulletin must be set to "en0". So make sure your Ethernet is working properly. It's also possible that you've some other devices set at "en0" such as WiFi or Bluetooth or the external WiFi adapter. For more information, read here:
Q. Sleep is not working. How do i fix it?
A.
For a working sleep function, power management must be implemented correctly.
Also a well patched DSDT/SSDT is required. Can vary from laptop to laptop.
For most of the time, the sleep is likely to be broken due to USB.
Q. Before login screen, there is a glitch. How do i fix it?
A.
This glitch is referred as garbled boot screen. This is due to the less DVMT prealloc
Q. What are problem reporting files?
A.
No problem can be diagnosed without complete information. Describing the exact scenario doesn't helps in all the case.
Also, make sure that your profile is filled as per the this FAQ.
Problem Reporting
In case you're not able to boot, provide the files below.
Screen shots :
  • Verbose photos
  • BIOS settings
  • Boot menu
  • System Preferences/Sound/Input
Clover Files :
  • Compress EFI/Clover, exclude the themes folder. Do not include complete EFI folder.
Put all files in a folder with your name, compress files as Zip and attach files using site attachments only. Do not use any external links.
  • If you can boot, but are having some other problem, describe the problem clearly and provide the problem reporting files.
Details
  • Copy of IOReg
  • Photo, wherever possible
  • Boot logs from Clover Configurator/DPCIManager
  • Kext cache output
sudo kextcache -i /
Clover Files :
This is almost all what you need to know. :)
