[Fix] Audio Distortion when using Headphones on Laptops
GIGABYTE Z370 AROUS GAMING 3
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
After enabling the Audio, you might encounter audio distortion/crackling sound when using headphones on laptops. To fix this issue, follow the steps below.
Some Audio Codecs which requires this fix
  • Realtek ALC233/ALC3236
  • Realtek ALC255
  • Realtek ALC256/ALC3246
  • Realtek ALC292
  • Realtek ALC294
  • Realtek ALC298
  • Realtek ALC299
Using VoodooHDA, this can be fixed for most of the times. But as per the laptop FAQ, VoodooHDA is not recommended.
  1. Download latest version of CodecCommander
  2. Extract the kext from the release folder.
  3. Mount your EFI Partition.
  4. Navigate to EFI/CLOVER/kexts/Other and place the kext here.
Alternatively, you can install the kext to S/L/E
Copy hda-verb to bin
Open Terminal
Type:
sudo cp -R /Users/yourusername/Desktop/hda-verb /usr/bin
When promoted, enter your password
Download the Jack fix attached below. This is a script which updates the pin widget control when using Headphones
hda-verb 0x19 SET_PIN_WIDGET_CONTROL 0x25
hda-verb 0x21 SET_UNSOLICITED_ENABLE 0x83
Copy Jack fix to bin
Open Terminal
Type:
sudo cp -R /Users/yourusername/Desktop/Jack fix /usr/bin
Monitor the Audio, and execute the script. The distortion should be fixed
Note: This will also fix switching issues for Headphones and Microphone Outputs. The script works for AppleHDA, AppleALC, CloverHDA, ADummyHDA and VoodooHDA.
Q. Is there any way to execute/run this script automatically?
A. Yes. In System Preferences, go to Users & Groups, select Login items, add Jack Fix to Login Items.
Problem Reporting
Details
  1. Audio Codec
  2. macOS version/CPU/GPU
  3. Copy of IOReg
  4. Method used for enabling Audio
  5. Installed CodecCommander.kext
  6. Output of (in Terminal):
sudo kextcache -i/
Screen shots:
  • DPCIManager/Status
  • System Information/Hardware/Audio/Intel High Definition Audio (All available devices)
  • System Preferences/Sound/Output
  • System Preferences/Sound/Input
Clover Files :
  • Compress EFI/Clover, exclude the themes folder Do not include complete EFI folder.
Put all files in a folder with your name, compress files as Zip and attach files using site attachments only. Do not use any external links.
Credits:
Mahmoud
Striker
Gigabyte B360 Gaming 3 WiFi
Intel Core i5 9400F
Sapphire Nitro plus Radeon RX580
Clover (UEFI)
iOS
It really works!!!
Reactions: Mirone
decros
Acer Swift 3 sf315-52-81hd
intel i7 8550u
Intel UHD 620
Clover (UEFI)
MacBook Pro
Android
It works like a charm. Just what I needed. Today I got audio in Mojave Thanks to this wonderful site, Mirone's AppleHDA patcher, and Rehadman CodeC Comander, and credits to the Jack fix developer, I don't know who is.
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
It works like a charm. Just what I needed. Today I got audio in Mojave Thanks to this wonderful site, Mirone's AppleHDA patcher, and Rehadman Code Comander, and credits to the Jack fix developer, I don't know who is.
Thanks for the appreciation. A long time ago, i had this issue so began to test with friend's laptops which had same issue. I tried to search and when debugging, i found the what was causing it and finally got the idea from the CodecCommander. Wrote a script and it works like a charm. EliteMacx86, Admin of EliteMacx86 forums is the developer of this fix. As it was a Jack related issue so i choose the name as "Jack Fix" and yes, it does the job. Happy to share.
Reactions: decros
Mirone
GA-Z270M-D3H
Intel Core i7 - 7700K
AMD - RX 560
10.15 (Beta)
Clover (UEFI)
iOS
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
I made some minor changes and I posted HERE I hope you do not mind.
thanks bro!
It has been so long!
That's great. As long as the original guide is linked and credit is given, i'm ok with it.
Reactions: Mirone
Mirone
GA-Z270M-D3H
AMD - RX 560
10.15 (Beta)
Clover (UEFI)
iOS
@EliteMacx86.
you're right, credits and links are fixed there.
Amdo
Alienware R5 17
i7 8750h
1070 Mobile
Clover (UEFI)
iMac
Android
Hey just wanted to say, this guide worked for me on my Alienware R5 17 - after a day of messing around with AppleALC and what not, I tried VoodooHDA + your guide and it works 100%!!
Thank you! :)
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Great!
Thank you! :)
You're welcome
My script works with AppleHDA, AppleALC, CloverHDA and VoodooHDA. BTW, what's your Audio Codec?
