[Fix] How to fix crash while using Netflix, Cnet and IMDb on macOS High Sierra and later
Likes
37
GIGABYTE Z370 AROUS GAMING 3
Intel Core i7 8700
NVIDIA Geforce GTX 1080Ti
Clover (UEFI)
MacBook Pro
Android, iOS
#1
With use of Intel HD Graphics, you might face crashing when using Safari, some Websites like Netflix. On some websites like Cnet and IMDb, if you play the video, a crash will be there. This issue is from macOS High Sierra and later.
This guide will fix all such issues when using Intel HD Graphics.
Download WhateverGreen and Lilu
The first step is to download the required kexts to enable audio. WhateverGreen doesn't works alone. WhateverGreen and Lilu is needed together to work with conjunction in order to fix this issue.
Downloads
The downloads are available in the Download section of this forum. Alternatively, you can download it from the link below.
  1. WhateverGreen
  2. Lilu
  • Download only RELEASE.zip file.
Mounting the EFI Partition and placing kexts
  1. Mount your EFI partition of your system drive
  2. Copy WhateverGreen.kext and Lilu.kext from RELEASE folder downloaded above.
  3. Navigate to EFI/Clover/kexts/Other and place the both the kexts to this location.
  • Do not use WhateverGreen.kext.dSYM, WhateverName and Lilu.kext.dSYM
Restart your System
After performing all the above steps, restart your system in order to fix the crashing issue.
Now you can enjoy browsing those sites which had crashing issues.
Likes: Max.1974
Similar threads
