Fixing error after Mojave post installation
mhendawy
HP 450 G4
Intel Core i7-7500U
Intel HD graphic 620
10.15 (Beta)
Clover (UEFI)
iOS
Thanks for your guide "[Guide] ASUS ZenBook UX530UX - Intel Core i5-7200U - 8GB RAM - Intel HD Graphics 620"
, please be informed that I followed this guide, and now I have Mojave 10.14.2 on my laptop " HP 450 Probook G4" but I have some issues regarding the battery meter, Audio sometimes not working , trackpad is working but not all gestures are working.brightness hotkeys are working.so please find my attached files regarding EFI folder. there are two EFI one I used in the preinstallation then the second one is the currently using.also please find a copy from the ioregiesteryexplorer.
GIGABYTE Z370 AROUS GAMING 3
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Your profile indicates you've 10.12.6. Please update/fix your profile as per FAQ. You should follow the Laptop installation guide not any specific Laptop guide unless you've the same manufacturer and series. Read here: https://www.elitemacx86.com/threads/guide-how-to-boot-macos-installer-on-laptops-using-clover-uefi-legacy.177/
The config.plist is not as per the guide. Except FakeSMC, all kexts are out of date in the first EFI.
For the second EFI, which is being used by your Laptop, has invalid config.plist which is not as per the guide. The kexts are out of date. The Clover/Kexts directory is not as per the guide. Shiki is already integrated in WEG and there's no point in using it separately along with WEG. AppleHDA shouldn't be installed in Clover/Kexts.
but I have some issues regarding the battery meter, Audio sometimes not working , trackpad is working but not all gestures are working.brightness hotkeys are working.so please find my attached files regarding EFI folder. there are two EFI one I used in the preinstallation then the second one is the currently using."
The ACPI has not been patched which is a important part for a Laptop. You cannot expect things to work without patching DSDT and SSDTs.
In order to enable the Battery meter, Brightness, Hotkeys, and fixing other issues, you must patch your DSDT and SSDTs. Read here: https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
Your IOReg is corrupt. Upload a new copy of IOReg.
Incomplete PR files attached. Kextcache output is missing.
mhendawy
HP 450 G4
Intel Core i7-7500U
10.15 (Beta)
Clover (UEFI)
iOS
Thanks for your feedback, I revised how I built my Mojave accordinlgy to the following link "https://www.elitemacx86.com/threads/guide-how-to-boot-macos-installer-on-laptops-using-clover-uefi-legacy.177/".
now I updated the out dated kexts: "VoodooPS2Controller.kext" & USBInjectAll.kext" and all the reset are up to dated. also I removed Shiki kext from the clover. I used the config.plist reference to this link "https://github.com/RehabMan/OS-X-Clover-Laptop-Config/blob/master/config_HD5300_5500_6000.plist"
I uploaded the IOreg. and the kext caches folder.
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
It looks like you did not followed the guide correctly and this is why it's not working correctly as it should. Intel Core i7-7500U has HD Graphics 620 Graphics then what's the point in using the HD5300_5500_6000 configuration?
Follow the guide carefully.
The IOReg is corrupt again. And you don't need to provide the kextcaches folder but kextcache output.
I suggest to read the guide very carefully. Make sure you read the Notes.
And provide the complete PR files.
mhendawy
HP 450 G4
Intel Core i7-7500U
10.15 (Beta)
Clover (UEFI)
iOS
okay thanks I 'll revise the guide again, but could you please help me for how to get IOreg good copy, as I just open the app and press update now and then save the copy soif there is guide for it and for how to export the kext cache only. moreover if you could list the other PR files that are required.
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Use IOReg 2.1
Read the FAQ or the install guide.
https://www.elitemacx86.com/threads/faq-read-first-questions-related-to-laptop.175/
Refer to FAQ
mhendawy
HP 450 G4
Intel Core i7-7500U
10.15 (Beta)
Clover (UEFI)
iOS
okay thanks for your help and cooperation, please find the attached files , I changed the config.plist to the correct one sorry for the mistake.
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
As per your system, you don't have any NVIDIA or AMD GPU, you must delete all the NVIDIA and AMD properties from the Devices section. Same in the Graphics section. Read the guide.
The logs looks old, the config.plist has been only changed. Provide a complete new set of PR files. Clover folder is missing. List what issues you're having.
mhendawy
HP 450 G4
Intel Core i7-7500U
10.15 (Beta)
Clover (UEFI)
iOS
Thanks for your reply, after kext up to date replacement , and use the config.plist mentioned in the following link: https://github.com/RehabMan/OS-X-Clover-Laptop-Config/blob/master/config_HD615_620_630_640_650.plist. now I have a problem in the audio device the system didn't detect at all.
graphic working normally
trackpad working normally but not all gestures
network & bluetooth & all USB ports are working normally
hot keys functions are working normally
I attached all the required files
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Problem Reporting files are incomplete. No Clover folder attached. And it looks like you did not followed the guide correctly. I pointed out the mistakes in the last post, but you ignored it.
See, https://www.elitemacx86.com/threads/fixing-error-after-mojave-post-installation.358/post-834
