[Guide] Enable Native Power Management on Laptops
GIGABYTE Z370 AROUS GAMING 3
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
On Laptops, it's quite important to have a working power management. Using a NullCPUPowerManagement is not a reliable option for laptops.
If you're using Clover Bootloader, you don't need to use NullCPUManagement as it's needed.
Before you begin, make sure you're using RehabMan's config.plist and following the laptop installation guide: https://www.elitemacx86.com/threads/guide-how-to-boot-macos-installer-on-laptops-using-clover-uefi-legacy.177/
For enabling native power management, you have two choice.
  • Clover Settings
  • A PowerManagement SSDT (Custom SSDT.aml)
Clover Settings
This method is one of the easiest method to enable macOS native power management without any need of a SSDT.
If you're using the above linked guide, this method is already enabled in all the config.plists from RehabMan.
If you're using a custom config.plist, you can configure the following settings listed below.
Make sure that you've set the correct UEFI/BIOS settings for your system and a correct SMBIOS.
Again, if you're using the above linked guide, a appropriate SMBIOS is already selected in all the config.plists. If you're using a custom config.plist, you can follow this guide: https://www.elitemacx86.com/threads/smbios-how-to-select-the-best-smbios-and-why.299/
Mount your EFI partition
Navigate to : EFI/Clover/config.plist
Open your config.plist file
Go to ACPI/SSDT/Generate and set PluginType=YES
Custom SSDT.aml
If you're using the above method, you don't need to use this method.
If you're having a SandyBridge or a IvyBridge CPU, you'll need to use this method.
Before you generate a SSDT for your CPU, make sure that the correct SMBIOS has been configured for your current CPU. You can generate a SMBIOS using Clover Configurator. For more information, follow the guide here: https://www.elitemacx86.com/threads/smbios-how-to-select-the-best-smbios-and-why.299/
1. Open Terminal and download the Piker Alpha's script.
curl -o ~/ssdtPRGen.sh https://raw.githubusercontent.com/Piker-Alpha/ssdtPRGen.sh/master/ssdtPRGen.sh
For newer CPUs, use beta branch.
curl -o ~/ssdtPRGen.sh https://raw.githubusercontent.com/Piker-Alpha/ssdtPRGen.sh/Beta/ssdtPRGen.sh
2. This will download the ssdtPRGen.sh script to your user directory. The next step is to change the file permission
chmod +x ~/ssdtPRGen.sh
3. For default SSDT generation, type:
sudo ~/ssdtPRGen.sh
4. Confirm y or n and it will generate the SSDT.
5. Open Finder and in menubar and click on Go to Folder
6. Type ~/Library/ssdtPRGen/
7. Now mount your EFI partition of your system drive. For more information, follow the guide here.
8. Copy ssdt.aml to /Volumes/EFI/EFI/Clover/ACPI/patched/
Notes:
  • The Power Management SSDT should always be named as SSDT.aml. If you're already having a SSDT.aml in the directory, rename it to SSDT-1.aml, SSDT-2.aml and so on.
  • The default generated SSDT is ssdt.aml. You can rename it to SSDT.aml without any issue.
  • If you're having a CPU which is not supported by the script, you'll need to provide custom data for the SSDT.aml generation.
  • For Haswell and later CPUs, this method is not needed. The same can be achieved via Clover settings only.
9. Restart your system
Testing Power Management
After restarting, you can test the power management. To test the power management, you need to use AppleIntelInfo.kext. You can either compile AppleIntelInfo.kext using XCode or can download from the post in the attachment.
1. Download and extract AppleIntelInfo.kext to your Desktop. Download the AppleIntelInfo.kext from here: https://www.elitemacx86.com/attachments/appleintelinfo-kext-zip.102/
2. Open Terminal
3. Type:
sudo kextutil /Users/your user name/Desktop/AppleIntelInfo.kext
When promoted, enter your password.
4. Type:
sudo cat /tmp/AppleIntelInfo.dat
5. The power states will be shown in the Terminal.
Other ways to determine a working power management
IORegistryExplorer
1.Open IORegistryExplorer and verify that X86PlatformPlugin loads under the CPU0 node.
2.For newer systems, search for "x86" in IOReg.
Intel Power Gadget Tool
  1. Install Intel Power Gadget.
  2. Let the system idle for a minute.
  3. After a minute or two, start doing tasks on your system. You can use a benchmarking software for the CPU to load.
Note:
  • Notice the graph in gadget tool. If you've a working graph, you've done it. When idle, the graph should be at 0, when at load, it should be higher.
Additional
On Laptop, you'll need to use some additional steps for a complete power management.
On Hackintoshes, the hiberation is not supported. So it's recommended to disable it.
sudo pmset -a hibernatemode 0
sudo rm /var/vm/sleepimage
sudo mkdir /var/vm/sleepimage
Also, it's a good idea to disable the other hibernation related functions.
sudo pmset -a standby 0
sudo pmset -a autopoweroff 0
Note:
  • When updating your hack, make sure that the hibernation is disabled as the system updates re-enables it.
AppleIntelInfo.kext
AppleIntelInfo.kext v1.4 Copyright © 2012-2015 Pike R. Alpha. All rights reserved
Settings:
logMSRs............................: 1
logIGPU............................: 1
logIntelRegs.......................: 1
logCStates.........................: 1
logIPGStyle........................: 1
InitialTSC.........................: 0x10a77f324eb
MWAIT C-States.....................: 286531872
Model Specific Regiters
MSR_CORE_THREAD_COUNT......(0x35)  : 0x40008
MSR_PLATFORM_INFO..........(0xCE)  : 0x4043DF1011200
MSR_PMG_CST_CONFIG_CONTROL.(0xE2)  : 0x1E008008
MSR_PMG_IO_CAPTURE_BASE....(0xE4)  : 0x51814
IA32_MPERF.................(0xE7)  : 0x4680F3D6A
IA32_APERF.................(0xE8)  : 0x271CEF7AB6
MSR_FLEX_RATIO.............(0x194) : 0x0
MSR_IA32_PERF_STATUS.......(0x198) : 0x1B4100001900
MSR_IA32_PERF_CONTROL......(0x199) : 0xA00
IA32_CLOCK_MODULATION......(0x19A) : 0x0
IA32_THERM_STATUS..........(0x19C) : 0x88390000
IA32_MISC_ENABLES..........(0x1A0) : 0x850089
MSR_MISC_PWR_MGMT..........(0x1AA) : 0x401CC1
MSR_TURBO_RATIO_LIMIT......(0x1AD) : 0x22222222
IA32_ENERGY_PERF_BIAS......(0x1B0) : 0x5
MSR_POWER_CTL..............(0x1FC) : 0x24005F
MSR_RAPL_POWER_UNIT........(0x606) : 0xA0E03
MSR_PKG_POWER_LIMIT........(0x610) : 0x42816000DD8090
MSR_PKG_ENERGY_STATUS......(0x611) : 0x15D41C3
MSR_PKG_POWER_INFO.........(0x614) : 0x78
MSR_PP0_CURRENT_CONFIG.....(0x601) : 0x238
MSR_PP0_POWER_LIMIT........(0x638) : 0x0
MSR_PP0_ENERGY_STATUS......(0x639) : 0x8988B9
MSR_PP0_POLICY.............(0x63a) : 0x0
MSR_PKGC6_IRTL.............(0x60b) : 0x8876
MSR_PKG_C2_RESIDENCY.......(0x60d) : 0x3FA7E14C84
MSR_PKG_C3_RESIDENCY.......(0x3f8) : 0x8D822839A6
MSR_PKG_C6_RESIDENCY.......(0x3f9) : 0x0
IA32_TSC_DEADLINE..........(0x6E0) : 0x10A7A9B6C2E
PCH device.................: 0x9D4E8086
Intel Register Data
CPU_VGACNTRL...............: 0x0
IS_ELSE(devid)
DCC........................: 0x000a3162 ()
CHDECMISC..................: 0x00000898 (none, ch2 enh enabled, ch1 enh enabled, ch0 enh disabled, flex disabled, ep not present)
C0DRB0.....................: 0x000a3162 (0x3162)
C0DRB1.....................: 0x0000000a (0x000a)
C0DRB2.....................: 0x00000000 (0x0000)
C0DRB3.....................: 0x4c900000 (0x0000)
C1DRB0.....................: 0x16ad3db0 (0x3db0)
C1DRB1.....................: 0xff8016ad (0x16ad)
C1DRB2.....................: 0xffffff80 (0xff80)
C1DRB3.....................: 0x5180ffff (0xffff)
C0DRA01....................: 0x164a4c90 (0x4c90)
C0DRA23....................: 0xff80164a (0x164a)
C1DRA01....................: 0x16d85180 (0x5180)
C1DRA23....................: 0xff8016d8 (0x16d8)
PGETBL_CTL.................: 0x00000000
VCLK_DIVISOR_VGA0..........: 0x00050004 (n = 5, m1 = 0, m2 = 4)
VCLK_DIVISOR_VGA1..........: 0x00000000 (n = 0, m1 = 0, m2 = 0)
VCLK_POST_DIV..............: 0x04004018 (vga0 p1 = 26, p2 = 2, vga1 p1 = 2, p2 = 2)
DPLL_TEST..................: 0x00000030 (, DPLLA input buffer disabled, DPLLB input buffer disabled)
CACHE_MODE_0...............: 0x09070138
D_STATE....................: 0x00000101
DSPCLK_GATE_D..............: 0x00000000 (clock gates disabled:)
RENCLK_GATE_D1.............: 0x0000000f
RENCLK_GATE_D2.............: 0x00000000
SDVOB......................: 0x00000000 (disabled, pipe A, stall disabled, not detected)
SDVOC......................: 0x00000136 (disabled, pipe A, stall disabled, detected)
SDVOUDI....................: 0x00000000
DSPARB.....................: 0x00000000
FW_BLC.....................: 0x5ce0e8c8
FW_BLC2....................: 0x00007fff
FW_BLC_SELF................: 0x0034009e
DSPFW1.....................: 0x00000000
DSPFW2.....................: 0x00000000
DSPFW3.....................: 0x00000000
ADPA.......................: 0x00000136 (disabled, pipe A, -hsync, +vsync)
LVDS.......................: 0x0000002c (disabled, pipe A, 18 bit, 2 channels)
DVOA.......................: 0x0000021a (disabled, pipe A, no stall, +hsync, +vsync)
DVOB.......................: 0x00000000 (disabled, pipe A, no stall, -hsync, -vsync)
DVOC.......................: 0x00000136 (disabled, pipe A, no stall, -hsync, +vsync)
DVOA_SRCDIM................: 0x00000000
DVOB_SRCDIM................: 0x00000000
DVOC_SRCDIM................: 0x00000000
BLC_PWM_CTL................: 0x00007fd0
BLC_PWM_CTL2...............: 0x9aa131d0
PP_CONTROL.................: 0x00000000 (power target: off)
PP_STATUS..................: 0x00000000 (off, not ready, sequencing idle)
PP_ON_DELAYS...............: 0x9aa01d90
PP_OFF_DELAYS..............: 0x00007fd0
PP_DIVISOR.................: 0x00000004
PFIT_CONTROL...............: 0x00000004
PFIT_PGM_RATIOS............: 0x00000136
PORT_HOTPLUG_EN............: 0x00000000
PORT_HOTPLUG_STAT..........: 0x00000000
DSPACNTR...................: 0x00000000 (disabled, pipe A)
DSPASTRIDE.................: 0x5d001fe0 (1560289248 bytes)
DSPAPOS....................: 0x00007f8f (32655, 0)
DSPASIZE...................: 0x090371a8 (29097, 2308)
DSPABASE...................: 0x00000000
DSPASURF...................: 0x00000000
DSPATILEOFF................: 0x00000000
PIPEACONF..................: 0x00000000 (disabled, single-wide)
PIPEASRC...................: 0x00007fff (1, 32768)
PIPEASTAT..................: 0x00007f8f (status: CRC_ERROR_INT_STATUS CRC_DONE_INT_STATUS GMBUS_INT_STATUS VSYNC_INT_STATUS DLINE_COMPARE_STATUS DPST_EVENT_STATUS SVBLANK_INT_STATUS VBLANK_INT_STATUS OREG_UPDATE_STATUS)
PIPEA_GMCH_DATA_M..........: 0x09037068
PIPEA_GMCH_DATA_N..........: 0x00000001
PIPEA_DP_LINK_M............: 0x00000000
PIPEA_DP_LINK_N............: 0x00000000
CURSOR_A_BASE..............: 0x00000000
CURSOR_A_CONTROL...........: 0x00000000
CURSOR_A_POSITION..........: 0x00000000
FPA0.......................: 0x00000388 (n = 0, m1 = 3, m2 = 8)
FPA1.......................: 0x00000000 (n = 0, m1 = 0, m2 = 0)
DPLL_A.....................: 0x00005010 (disabled, non-dvo, VGA, TV B/C clock, unknown mode, p1 = 0, p2 = 0)
DPLL_A_MD..................: 0x00000000
HTOTAL_A...................: 0x00000000 (1 active, 1 total)
HBLANK_A...................: 0x00000000 (1 start, 1 end)
HSYNC_A....................: 0x8e766c88 (27785 start, 36471 end)
VTOTAL_A...................: 0x00007fff (32768 active, 1 total)
VBLANK_A...................: 0x00000060 (97 start, 1 end)
VSYNC_A....................: 0x00000000 (1 start, 1 end)
BCLRPAT_A..................: 0x00000000
VSYNCSHIFT_A...............: 0x00000000
DSPBCNTR...................: 0x09038198 (disabled, pipe B)
DSPBSTRIDE.................: 0x00000000 (0 bytes)
DSPBPOS....................: 0x00000000 (0, 0)
DSPBSIZE...................: 0x00000000 (1, 1)
DSPBBASE...................: 0x00000001
DSPBSURF...................: 0x00000000
DSPBTILEOFF................: 0x00007f8f
PIPEBCONF..................: 0x00000000 (disabled, single-wide)
PIPEBSRC...................: 0x00000000 (1, 1)
PIPEBSTAT..................: 0x00000000 (status:)
PIPEB_GMCH_DATA_M..........: 0x00000000
PIPEB_GMCH_DATA_N..........: 0x00000000
PIPEB_DP_LINK_M............: 0x5d001fe0
PIPEB_DP_LINK_N............: 0x00007f8f
CURSOR_B_BASE..............: 0x00007f8f
CURSOR_B_CONTROL...........: 0x5d001fe0
CURSOR_B_POSITION..........: 0x090370e0
FPB0.......................: 0x00000388 (n = 0, m1 = 3, m2 = 8)
FPB1.......................: 0x00000000 (n = 0, m1 = 0, m2 = 0)
DPLL_B.....................: 0x00000000 (disabled, non-dvo, VGA, default clock, unknown mode, p1 = 0, p2 = 0)
DPLL_B_MD..................: 0x00000000
HTOTAL_B...................: 0x00000000 (1 active, 1 total)
HBLANK_B...................: 0x00000000 (1 start, 1 end)
HSYNC_B....................: 0x9a909670 (38513 start, 39569 end)
VTOTAL_B...................: 0x00007fd0 (32721 active, 1 total)
VBLANK_B...................: 0x0000004c (77 start, 1 end)
VSYNC_B....................: 0x0000010b (268 start, 1 end)
BCLRPAT_B..................: 0x00000000
VSYNCSHIFT_B...............: 0x00000004
VGACNTRL...................: 0x09038418 (enabled)
TV_CTL.....................: 0x5c5024a0
TV_DAC.....................: 0x00007fff
TV_CSC_Y...................: 0x879468a8
TV_CSC_Y2..................: 0x00007fff
TV_CSC_U...................: 0x8f2d00f0
TV_CSC_U2..................: 0x00007fff
TV_CSC_V...................: 0x8f2d00f0
TV_CSC_V2..................: 0x00007fff
TV_CLR_KNOBS...............: 0x5c5024a0
TV_CLR_LEVEL...............: 0x00007fff
TV_H_CTL_1.................: 0x00000000
TV_H_CTL_2.................: 0x00000000
TV_H_CTL_3.................: 0x87946730
TV_V_CTL_1.................: 0x00007fff
TV_V_CTL_2.................: 0x87b67068
TV_V_CTL_3.................: 0x00007fff
TV_V_CTL_4.................: 0x8f2d0140
TV_V_CTL_5.................: 0x00007fff
TV_V_CTL_6.................: 0x5c5024a0
TV_V_CTL_7.................: 0x00007fff
TV_SC_CTL_1................: 0x87946e00
TV_SC_CTL_2................: 0x00007fff
TV_SC_CTL_3................: 0x8f2d00f0
TV_WIN_POS.................: 0x8f2d00f0
TV_WIN_SIZE................: 0x00007fff
TV_FILTER_CTL_1............: 0x00000000
TV_FILTER_CTL_2............: 0x00000000
TV_FILTER_CTL_3............: 0x87946ca8
TV_CC_CONTROL..............: 0x87b67130
TV_CC_DATA.................: 0x00007fff
TV_H_LUMA_0................: 0x87952868
TV_H_LUMA_59...............: 0x00000000
TV_H_CHROMA_0..............: 0x8f2d00f0
TV_H_CHROMA_59.............: 0x00007fff
FBC_CFB_BASE...............: 0x09071218
FBC_LL_BASE................: 0x00000001
FBC_CONTROL................: 0x00000000
FBC_COMMAND................: 0x00000000
FBC_STATUS.................: 0x00000000
FBC_CONTROL2...............: 0x00000000
FBC_FENCE_OFF..............: 0x00000000
FBC_MOD_NUM................: 0x5d001fe0
MI_MODE....................: 0x00000000
MI_ARB_STATE...............: 0x00000000
MI_RDRET_STATE.............: 0x00000001
ECOSKPD....................: 0x00000000
DP_B.......................: 0x00000000
DPB_AUX_CH_CTL.............: 0x00000000
DPB_AUX_CH_DATA1...........: 0x00000000
DPB_AUX_CH_DATA2...........: 0x00000000
DPB_AUX_CH_DATA3...........: 0x00000000
DPB_AUX_CH_DATA4...........: 0x00000000
DPB_AUX_CH_DATA5...........: 0x00000000
DP_C.......................: 0x00050004
DPC_AUX_CH_CTL.............: 0x04004010
DPC_AUX_CH_DATA1...........: 0x00005010
DPC_AUX_CH_DATA2...........: 0x3b220230
DPC_AUX_CH_DATA3...........: 0x00007fc0
DPC_AUX_CH_DATA4...........: 0x3b2202a0
DPC_AUX_CH_DATA5...........: 0x00007fc0
DP_D.......................: 0x00000000
DPD_AUX_CH_CTL.............: 0x88217709
DPD_AUX_CH_DATA1...........: 0x001dffff
DPD_AUX_CH_DATA2...........: 0x00001280
DPD_AUX_CH_DATA3...........: 0x00000001
DPD_AUX_CH_DATA4...........: 0x00050005
DPD_AUX_CH_DATA5...........: 0x00000003
AUD_CONFIG.................: 0x00000000
AUD_HDMIW_STATUS...........: 0x00000000
AUD_CONV_CHCNT.............: 0x00000000
VIDEO_DIP_CTL..............: 0x00000000
AUD_PINW_CNTR..............: 0x00000000
AUD_CNTL_ST................: 0x00000000
AUD_PIN_CAP................: 0x00000000
AUD_PINW_CAP...............: 0x00000000
AUD_PINW_UNSOLRESP.........: 0x00000000
AUD_OUT_DIG_CNVT...........: 0x00000000
AUD_OUT_CWCAP..............: 0x00000000
AUD_GRP_CAP................: 0x00000000
FENCE  0...................: 0x5d001fe0 (disabled)
FENCE  1...................: 0x00007f8f (enabled, Y tiled,  128 pitch, 0x00000000 - 0x08000000 (131072kb))
FENCE  2...................: 0x09070020 (disabled)
FENCE  3...................: 0x00000001 (enabled, X tiled,  512 pitch, 0x00000000 - 0x00100000 (1024kb))
FENCE  4...................: 0x00000000 (disabled)
FENCE  5...................: 0x00000000 (disabled)
FENCE  6...................: 0x00000000 (disabled)
FENCE  7...................: 0x00000000 (disabled)
FENCE  8...................: 0x00000000 (disabled)
FENCE  9...................: 0x00000000 (disabled)
FENCE  10..................: 0x00000000 (disabled)
FENCE  11..................: 0x00000000 (disabled)
FENCE  12..................: 0x00000000 (disabled)
FENCE  13..................: 0x00000000 (disabled)
FENCE  14..................: 0x5d001fe0 (disabled)
FENCE  15..................: 0x00007f8f (enabled, Y tiled,  128 pitch, 0x00000000 - 0x08000000 (131072kb))
FENCE START 0..............: 0x00000000 ()
FENCE END 0................: 0x00000000 ()
FENCE START 1..............: 0x00000000 ()
FENCE END 1................: 0x00000000 ()
FENCE START 2..............: 0x00000000 ()
FENCE END 2................: 0x00000000 ()
FENCE START 3..............: 0x5d001fe0 ()
FENCE END 3................: 0x00007f8f ()
FENCE START 4..............: 0x09071038 ()
FENCE END 4................: 0x00000001 ()
FENCE START 5..............: 0x00000000 ()
FENCE END 5................: 0x00000000 ()
FENCE START 6..............: 0x00000000 ()
FENCE END 6................: 0x00000000 ()
FENCE START 7..............: 0x00000000 ()
FENCE END 7................: 0x00000000 ()
FENCE START 8..............: 0x5d001fe0 ()
FENCE END 8................: 0x00007f8f ()
FENCE START 9..............: 0x09071060 ()
FENCE END 9................: 0x00000001 ()
FENCE START 10.............: 0x00000000 ()
FENCE END 10...............: 0x00000000 ()
FENCE START 11.............: 0x00000000 ()
FENCE END 11...............: 0x00000000 ()
FENCE START 12.............: 0x00000000 ()
FENCE END 12...............: 0x00000000 ()
FENCE START 13.............: 0x5d001fe0 ()
FENCE END 13...............: 0x00007f8f ()
FENCE START 14.............: 0x09071088 ()
FENCE END 14...............: 0x00000001 ()
FENCE START 15.............: 0x00000000 ()
FENCE END 15...............: 0x00000000 ()
INST_PM....................: 0x00000000
p1 out of range
ref out of range
pipe A dot 0 n 0 m1 3 m2 8 p1 1 p2 10
p1 out of range
pipe B dot 168000 n 0 m1 3 m2 8 p1 1 p2 10
CPU Ratio Info:
CPU Low Frequency Mode.............: 400 MHz
CPU Maximum non-Turbo Frequency....: 1800 MHz
CPU Maximum Turbo Frequency........: 3400 MHz
IGPU Info:
IGPU Current Frequency.............:    0 MHz
IGPU Minimum Frequency.............:  300 MHz
IGPU Maximum Non-Turbo Frequency...:  300 MHz
IGPU Maximum Turbo Frequency.......: 1100 MHz
IGPU Maximum limit.................: No Limit
CPU P-States [ (12) 18 26 ] iGPU P-States [ ]
CPU C3-Cores [ 0 6 7 ]
CPU C3-Cores [ 0 2 3 6 7 ]
CPU C3-Cores [ 0 2 3 4 5 6 7 ]
CPU C3-Cores [ 0 1 2 3 4 5 6 7 ]
CPU P-States [ 12 (16) 18 26 ] iGPU P-States [ ]
CPU P-States [ 12 (16) 17 18 26 ] iGPU P-States [ ]
CPU P-States [ 12 (16) 17 18 21 26 ] iGPU P-States [ ]
CPU P-States [ (12) 14 16 17 18 21 26 ] iGPU P-States [ ]
CPU P-States [ (12) 13 14 16 17 18 21 26 ] iGPU P-States [ ]
CPU P-States [ (12) 13 14 15 16 17 18 21 26 ] iGPU P-States [ ]
CPU P-States [ 12 13 14 15 16 17 18 (20) 21 26 ] iGPU P-States [ (30) ]
CPU P-States [ 12 13 14 15 (16) 17 18 20 21 24 26 ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 16 17 18 20 21 (23) 24 26 ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 16 17 18 20 21 23 24 26 (31) ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 16 17 18 20 21 23 24 26 27 31 (32) ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 16 17 18 20 21 23 (24) 26 27 30 31 32 ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 16 17 18 20 21 22 23 24 26 27 30 (31) 32 ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 16 17 18 20 21 22 23 24 25 26 27 (30) 31 32 ] iGPU P-States [ 30 ]
CPU P-States [ 12 13 14 15 (16) 17 18 20 21 22 23 24 25 26 27 29 30 31 32 ] iGPU P-States [ 30 ]
CPU P-States [ (12) 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 29 30 31 32 ] iGPU P-States [ 30 ]
CPU P-States [ (12) 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ] iGPU P-States [ 30 ]
CPU P-States [ (12) 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ] iGPU P-States [ 2 30 ]
CPU P-States [ 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 (34) ] iGPU P-States [ 2 30 ]
CPU P-States [ (9) 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 34 ] iGPU P-States [ 2 30 ]
CPU P-States [ (9) 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 34 ] iGPU P-States [ 2 30 ]
CPU P-States [ 9 (10) 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 34 ] iGPU P-States [ 2 30 ]
CPU P-States [ 9 10 11 (12) 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 ] iGPU P-States [ 2 30 ]
CPU P-States [ 9 10 11 12 13 14 15 (16) 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 ] iGPU P-States [ 2 30 ]
Intel Power Gadget/Screenshot
Credits:
Pike R. Alpha
mark
Asus ZenBook UX430UNR
i7-8550u
Intel UHD 620 / Nvidia MX150
Clover (UEFI)
MacBook Pro
iOS
I did all, and how to understand its work or no?
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Your IOReg proves that your PM is working. The guide states how to check if your PM is working. But you should use a new SMBIOS for MacBookPro14,1
mark
i7-8550u
Clover (UEFI)
MacBook Pro
iOS
Thank you
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Reactions: mark
mark
i7-8550u
Clover (UEFI)
MacBook Pro
iOS
Attached
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
Looks like you did not used the system. As mentioned, after loading the kext, you must run a bunch of task so that the CPU goes to it's full speed.
mark
i7-8550u
Clover (UEFI)
MacBook Pro
iOS
how is it now?
Intel Core i9 9900K
Clover (UEFI)
MacBook Pro
Android, iOS
how is it now?
Looks good. The PM is working and all the cores are being utilised and CPU runs at it's full speed. Complete 4.0GHz
Reactions: mark
mark
i7-8550u
Clover (UEFI)
MacBook Pro
iOS
Oh god, i glad for this. Thank you
