Thanks for this guide.
I can get it work on my HP EliteBook 850 G5. I have thunderbolt in legacy mode in BIOS and I can connect USB-C drive.
However it breaks sleep mode. When I tried to wake from sleep I needed to shut down and start again with this error:
panic(cpu 2 caller 0xffffff7f9e352399): "NHI0(MacBookPro15,4): thunderbolt power on failed 0xffffffff\n"@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/IOPCIFamily/IOPCIFamily-370.100.21/IOPCIBridge.cpp:1398
Backtrace (CPU 2), Frame : Return Address
0xffffff83d77ab9e0 : 0xffffff801d91f5cd
0xffffff83d77aba30 : 0xffffff801da58b05
0xffffff83d77aba70 : 0xffffff801da4a68e
0xffffff83d77abac0 : 0xffffff801d8c5a40
0xffffff83d77abae0 : 0xffffff801d91ec97
0xffffff83d77abbe0 : 0xffffff801d91f087
0xffffff83d77abc30 : 0xffffff801e0c27cc
0xffffff83d77abca0 : 0xffffff7f9e352399
0xffffff83d77abcc0 : 0xffffff7f9e339fcf
0xffffff83d77abd20 : 0xffffff7f9e33a180
0xffffff83d77abd60 : 0xffffff7f9e33a334
0xffffff83d77abda0 : 0xffffff7f9e33a4fc
0xffffff83d77abdc0 : 0xffffff7f9e3386f6
0xffffff83d77abe10 : 0xffffff7f9e34301f
0xffffff83d77abe30 : 0xffffff801e0148a4
0xffffff83d77abea0 : 0xffffff801e0146aa
0xffffff83d77abec0 : 0xffffff801d961565
0xffffff83d77abf40 : 0xffffff801d961091
0xffffff83d77abfa0 : 0xffffff801d8c513e
Kernel Extensions in backtrace:
com.apple.iokit.IOPCIFamily(2.9)[BE052F4D-9B80-3FCD-B36D-BACB7DEE0DF2]@0xffffff7f9e331000->0xffffff7f9e369fff
No PR files attached.
Nevermind, I just get it to work!
Thank you so much for this solution. I can finaly switch TB3 in BIOS to "Native + Low Power mode".
All works including sleep.
BTW. I just tested that SSDT files are enough. I don't need kext and driver to work.
And does the Hotplug works without the kext and driver?
Depends on your IOReg.
This is very normal and already explained in guide.
TQ for replay :)
I've connected to My book thunderbolt 2TB but nothing came out
I tried with the thunderbolt Ultra studio Recoder, it worked. Just My book thunderbolt 2TB but nothing came out
is there another way to get it working?
  • Zabidi’s iMac.ioreg.zip
  • patched.zip
  • Config.zip
BOOWhhfasd
